decision for a silent case
Go to solution Solved by SeanAngelo,
hi i´m looking for a nice silent atx case
which one is better?
bitfenix ghost
or
be quiet silent base 600
regards
BeQuiet case
bitfenix ghost
or
regards
CPU i7 4790K 4,7Ghz Cooling:Corsair H100iGTX+Noctua NF-F12PWM GPU: EVGA 1080ti SC+ ACX2.0+ RAM:16GB DDR3 1866mhz Crucial Balistics Tactical Tracer Mobo:ASUS Z97-AR PSU:EVGA 750W G2 Supernova Case:Fractal Meshify C Storage:500GB Samsung 850 evo, 900GB Toshiba Game Storage SSD, 2TB Data HDD
i7 4790k Devils Canyon OC @4,6Ghz,Cooler Corsair h100i GTX, GPU EVGA 980Ti SC+ ACX 2.0+ @ stoc
http://linustechtips.com/main/topic/278610-display-technology-faqmythbuster/
https://linustechtips.com/topic/466600-decision-for-a-silent-case/
Out of those, I'd have the Silent Base 600. The Define series from Fractal is also good for quietness :)
Other systems I've built:
I have no experience with the base 600, but I do use a base 800 for my rig, which i can attest, is very, very, very quiet. If be quiet has any soft of standing, I would then wager that the base 600 would be also very quiet. Components make a big deal though. I am only using be quiet fans, and some vardar for my rads.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
bitfenix ghost
or
regards
BeQuiet case
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
CPU: Intel Core i7-4790K 4.0GHz
CPU Cooler: Noctua NH-D14 65.0 CFM CPU
Motherboard: ASUS Z97 A ATX LGA1150
Memory: Crucial Ballistix Sport 16GB (2 x 8GB) DDR3-1600
Storage: Samsung 850 EVO-Series 500GB 2.5"
Video Card: EVGA GeForce GTX 980ti Hybrid
Case: silent :P
Power Supply: EVGA SuperNOVA G2 700W-750 80+ Gold                         should be enough
A 'silent' case can only do so much. You also need quiet components inside of your case (fans, pumps if you use water cooling, etc), just so ya know.
