​Assuming infinitely great internet everywhere, could I not build an amazing machine and connect to it virtually via a shitty laptop and get great performance on the go?
Just a guy who peaked at building back in the days of the GTX 980. If you see me here, assume i have technical knowledge akin to a committed hobbyist builder back then. If something's changed, you'll need to tell me(nicely plz). I'm probably asking for help with the modern build scene since I have no clue what's going on.
https://linustechtips.com/topic/466138-stream-machine/
Or just buy a good laptop.
CPU: Intel i5 4690k @ 4.3 GHz       GPU: MSI GTX 980                      Cooling: be quiet! Pure Rock                     OS: Windows 7            Monitor: BenQ XL2411Z
Motherboard: AsRock Z97 PRO4   PSU: Corsair 600W CX600M       Keyboard: Razer BlackWidow Ultimate   SSD: Intel 120GB 520   Headset: HyperX Cloud II
RAM: 12GB Crucial Ballistix            Case: Corsair 750D                       Mouse: Logitech G502                         HDD: Seagate 1TB        Speakers: Audioengine A5+
https://linustechtips.com/topic/466138-stream-machine/#findComment-6254734
No, because with any streaming solution I'm aware of you have to be on the same network. I'm sure there's solutions around that, but those are going to limit the bandwidth and the latency. And that latency is going to be horrible man. No way to game on that.
For good gaming on the go there is, afaik, only high performance laptops, or possibly a really small mini ITX machine with something like that 13" monitor they reviewed a while back. if you're insane.
https://linustechtips.com/topic/466138-stream-machine/#findComment-6254768
This^^^^
That is a great answer!
https://linustechtips.com/topic/466138-stream-machine/#findComment-6254791
You could, but you wouldn't really be able to play games through the remote connection, maybe just do work or grab files
How much did you want to spend on your laptop?
https://linustechtips.com/topic/466138-stream-machine/#findComment-6255645
This was all hypothetical. I don't actually want to do it.
https://linustechtips.com/topic/466138-stream-machine/#findComment-6257067
