So I just ordered a 4590, and I was reading in a thread that somebody "overclocked" it to 3.7 GHz. Now I know that the base speed is 3.3 and it turbos up to 3.7 without any modifications, but if I were to do what this guy did and change the multiplier so its 3.7 GHz, would this make all 4 cores turbo up to 3.7 instead of just one? (I believe only one core can turbo all the way to 3.7)
Main PC: i5 4590 @ 3.5 GHz ♦ RX 480 Armor OC ♦ 16 GB DDR3 ♦ GA-Z97-HD3 ♦ 120 GB 840 EVO ♦ 120 GB Intel 520 ♦ W10 Home
Scrapyard PC: Xeon X5460 @ 3.8 GHz ♦ HD 7870 ♦ 8 GB DDR2 ♦ GA-P35-DS3L ♦ 80 GB Intel 320 ♦ 160 GB WD Caviar SE ♦ W10 Home
https://linustechtips.com/topic/465877-turbo-boost-question/
Turbo boost varies on how many cores are being used. your cpu likely will only boost to 2.7ghz if only 1 core is active, and changing the multiplier to 37 just makes it so that all 4 cores boost up to 3.7ghz.
Increasing the multiplier above the turbo boost level, just makes all the cores boost when under load, rather than it selecting how high they go depending on how many cores are active.
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/465877-turbo-boost-question/#findComment-6251503
the 4590 CPU ratio locked so no overclocking. he probably just enabled the turbo boost feature and went "luk at meh i soo kuul i can uvercluck me pruccossrr weeeeeee"
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
https://linustechtips.com/topic/465877-turbo-boost-question/#findComment-6251504
I know how turbo boost works, and I know the 4590 is a locked chip, that is why I was asking the question. I saw someone in another thread say they were able to raise the multiplier to the max turbo boost speed (and nothing above that obviously) and I was just curious if that would make all cores turbo.
https://linustechtips.com/topic/465877-turbo-boost-question/#findComment-6251562
No all four cores cannot turbo at once and they will not be constantly turbo'ed either. Thats not how turbo boost works
https://linustechtips.com/topic/465877-turbo-boost-question/#findComment-6251624
I have a non k cpu as well. The max turbo boost for my chip is 3.9 ghz on one core, but I'm able to raise the multiplier to 41, thereby increasing all 4 cores to 4.1ghz. Anything over 41 will show up in cpuz (it will say 8-43), but it wills till only turbo till 4.1 ghz.
Also I would have thought that the 4590 would have a higher clock than 3.3ghz...
https://linustechtips.com/topic/465877-turbo-boost-question/#findComment-6251695
Thanks!
I also thought the 4590 would have a higher clock but Intel wants you to step up to the 4690(k) for $30-$50 more.
https://linustechtips.com/topic/465877-turbo-boost-question/#findComment-6251790
