Help regarding Laptop RAM
Go to solution Solved by exercutor5,
Hi,
I intend to buy a new memory stick for my old laptop Sony Vaio VPCEA23EN.
It had two DDR3 1066 Mhz PC3 - 8500 SODIMM. Do i need to consider the frequency and voltage of the RAM i am planning to buy as well.
As i am a bit concerned about compatibility. Or is there anything else i should be aware of.
Any help/insight regarding this will be appreciated.
I'm assuming your VAIO has the i3-350M. The 350M only supports 8GB of RAM, in either 800 or 1066MHz speeds. Voltage should be 1.5V, which is the standard for DDR3, whereas 1.35V is DDR3L.
Hi,
https://linustechtips.com/topic/465788-help-regarding-laptop-ram/
Hi,
Frost | 7700K @ 4.9GHz 1.36v, delidded | Asus DUAL GTX 1060 6GB OC | Corsair LPX 16GB DDR4 2800MHz | Samsung 960 EVO 250GB SSD + Toshiba 1TB HDD + Toshiba 2TB HDD + Samsung 860 EVO 1TB SSD for macOS | Asus PRIME Z270-A | Fractal Design Celsius S24 | Seasonic M12-II 620W PSU | Corsair 400C White | NZXT Hue+
Samsung Galaxy S8 | Stock
Ticwatch E (Black) | Ticwatch Brown Leather Strap
