OBS/Twitch streaming ideal CPU usage %
It depends on what game you are playing, if you are playing universe sandbox compared to tetris, since if you only have x ammount of CPU power left over, then you might not be able to run your game at 60 FPS
also, if you reach 100% the CPU will turboclock, which will bring the % down for a while.
Long live Stalin, he loves you; sing these words, or you know what he’ll do!
Occasionally reach 100% with a 4.6 ghz 4790k, but without dropping frames or losing framerate ingame
CPU: I7 4790K(4.6@1.252v)                               Case: Fractal Design Define R5 Windowed(Black)           Cooler: CM 212 EVO + NF F12 iPPC
RAM: HyperX Fury 1600MHZ CL10 2x4GB      Storage: Samsung 850 EVO(250GB) + WD Red(2TB)      PSU: Corsair RM750 (and no, it hasn't blown up!)
MoBo: Asus Maximus VII Ranger                      Graphics: MSI GTX 970 TwinFrozr (1494MHZ Core)       OS: Windows 10 Enterprise
100% would be best. But I've got 4770K to 60% while streaming. Note, CPUs performance won't change much when it hits 100%. You can notice it maxing out when game slows or you drop frames. Then it time to lower streaming settings.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Shouldn't be too bad, for streaming though, more cores = better quality. I had to get a 10 core Xeon just to stream Minecraft at anything higher than potato quality.
Something must of been wrong then, literally almodt anything can stream minecraft..
Intel Core i7 7770K | 32 GB's Ram 3000MHz | GTX 1080 Ti | 250GB SSD | 3TB 7400 RPM | Sound Blaster Z | ASUS ROG MG278Q | Razer Blackwidow Chroma | Final Mouse 2015 | Blue Yeti | Seinheiser HD 600's | Beyerdynamic DT 990 Pro | Aune T1 MK2
Nope. Pristine custom build without any bloatware or viruses. I had all my drivers, and there were no incompatibilities. What most people don't think about is that although Minecraft is a relatively simple game, it's render engine is so poorly optimized it's hard to get 60FPS on a GTX 760.
