i was wondeing if it would make my stream better if i were to buy a capture card and stream with my laptop and game on my desktop (dual pc streaming setup) or to buy a new cooler for my CPU and overclock it around 4.7-5gHz.
i use the veryfast preset right now, and i was wondering which i would be able to encode slower with.
cpu in desktop is g3258
if i was to dual stream it would use an i5-2450m dual core to stream. based on benchmarks the g3258 shits on the 2450m because the g3258 has 60% faster cores.
https://linustechtips.com/topic/465665-capture-card-or-cooler/
capture card
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/465665-capture-card-or-cooler/#findComment-6248593
I'd say get the capture card. The G3258's 2 cores and lack of things like hyperthreading make it not very ideal for things like multitasking while under load. While I suggest EVENTUALLY getting a Hyper 212 Evo for overclocking, getting a capture card so you can actually stream from your laptop takes a lot of the load off of your desktop. Hell, if you can get it cheap enough, you could get the Evo as well as getting the capture card, but getting the card should be the first priority.
https://linustechtips.com/topic/465665-capture-card-or-cooler/#findComment-6248705
