Heaphone help
Go to solution Solved by zzenigmaxzz,
nope they will plug right in to your onboard audio of your mobo or your console if you decide to use them that way
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
https://linustechtips.com/topic/465322-heaphone-help/#findComment-6244462
Probably not, I just on board audio for my headphones, unless there is something like static I wouldn't recommend getting one.
https://linustechtips.com/topic/465322-heaphone-help/#findComment-6244466
