Does EVGA Care?
Go to solution Solved by manikyath,
since evga doesnt care if you swap coolers, i dont think they'll mind overclocking.
now if you're straight up stupid and fry the card by dragging the voltage slider ALL the way up...
I'm considering OCing my EVGA SC ACX 2.0 980 Ti since on heavily modded Skyrim I get sub-60 FPS. In terms of a warranty should something go wrong, would EVGA replace my card or is the warranty automatically voided? I know EVGA is pretty chill when it comes to this stuff.
Guide to GTX 900 Series: http://linustechtips.com/main/topic/457526-nvidia-900-series-basic-performance-guide/
Performance expert, building noob.
There is no such thing as excess in hardware.
https://linustechtips.com/topic/464113-does-evga-care/
Well, there is no way of telling that your card was overclocked.
https://linustechtips.com/topic/464113-does-evga-care/#findComment-6229206
if it start to have issues. you can turn your clocks back to stock then send it back to them...
https://linustechtips.com/topic/464113-does-evga-care/#findComment-6229221
EVGA doesnt care, if you return the card if its broke. It needs to run on stock config. If you dont do that, you wont get a refund.
CPU: Intel I7 4790K 4.8 Ghz || Mobo: ASUS ROG Maximus Hero 6 Z87 || Ram: Corsair Vengeance 16 GB 1600 Mhz || GPU: ASUS GTX 980 Ti STRIX || Storage: 2 x SSD Samsung 840 EVO 250 GB RAID 0 HDD Western Digital 1 TB Black || PSU: Corsair AX 860 watt || Cooling: 2 x AF 140mm (front), 2 AF120 Blue LED (bottom and back), 2 SP120 (top on radiator) ||  CPU cooler: Corsair H100i GTX || Case: Corsair obsidian 750D <3 <3 <3
https://linustechtips.com/topic/464113-does-evga-care/#findComment-6229260
EVGAs warranty explicitly covers overclocking.
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/464113-does-evga-care/#findComment-6229265
