Reading values from programs with scripts
Go to solution Solved by manikyath,
if those programs have an API you can hook into - thats all okay. (openhardwaremonitor has hooks that can be used by for example rainmeter)
otherwise... you're gonna have to delve into the territory that many game bot developers walk into, which i'm not gonna touch, at all.
So if a program doesn't have an API and I tried to do everything by reading memory values - is there any guarantee that the objects im reading will be stored in the same memory location every time i run the program, or will they just be random every single time?
