Hi! I'm planning on starting a skylake build, and I'm on a budget ($500~$600 without graphics card). I was thinking of going for B150 motherboards, to cut down on price. Is this ok? Or am I missing out on not going for the H170 motherboards? I don't plan to OC btw.
I plan to buy my graphics card separately (r9 390), down the line, so as not to be too heavy on the wallet. Please help me guys, thanks!
Things I've set my sights on:
Processor: i5-6500
Motherboard: MSI B150 (?) or Gigabyte H170 gaming 3
RAM: Corsair Vengeance LPX ddr4 8gb 2400
SSD: Crucial BX-100 250GB (I have an old laptop drive I can reuse for mass storage)
PSU: Seasonic M12II-520
Case: please help?
Any and all suggestions and comments are welcome, thanks!
https://linustechtips.com/topic/463538-help-with-first-ever-build-skylake-d/
Processor: i5-6500
Case: please help?
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.99 @ SuperBiiz)
Motherboard: Asus Z97-E ATX LGA1150 Motherboard  ($92.98 @ Newegg)
Storage: Crucial BX100 250GB 2.5" Solid State Drive  ($79.99 @ Amazon)
Case: Corsair 200R ATX Mid Tower Case  ($64.99 @ NCIX US)
Power Supply: SeaSonic S12G 650W 80+ Gold Certified ATX Power Supply  ($85.98 @ Newegg)
Total: $608.81
Generated by PCPartPicker 2015-10-08 06:09 EDT-0400
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
You could just go with this build, and upgrade the CPU later if it's really holding you back, you'll be able to game much better in the mean time
PCPartPicker part list: http://pcpartpicker.com/p/LswqFT
Price breakdown by merchant: http://pcpartpicker.com/p/LswqFT/by_merchant/
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor  ($59.00 @ Amazon)
Motherboard: Gigabyte GA-F2A88X-D3H ATX FM2+ Motherboard  ($74.88 @ OutletPC)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory  ($36.00 @ Newegg)
Storage: Hitachi Deskstar 1TB 3.5" 7200RPM Internal Hard Drive  ($38.90 @ Amazon)
Video Card: Diamond Radeon R9 290 4GB Video Card  ($249.99 @ Amazon)
Case: Deepcool TESSERACT BF ATX Mid Tower Case  ($33.99 @ Newegg)
Power Supply: Rosewill HIVE 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.99 @ Newegg)
Total: $552.75
Generated by PCPartPicker 2015-10-08 06:29 EDT-0400
I have to agree with everyone above. Your budget is too low for a good skylake build. Haswell processors are still pretty good and I don't think you'll be disappointed with them. :)
~~ Intel Xeon E5-2696 v4, Asus X99-A II, Adata 2x8 GB, EVGA GTX 980Ti FTW, InWin 303, Dell U3415W~~
Total: $552.75
Hi! I already have a separate budget for video card - either 970 or 390. So my $600 budget was for the other parts of the build :D
So your budget is 900-1000?
The build is meant for a 2nd GPU down the line, so you could get it down with a less expensive motherboard and PSU
PCPartPicker part list: http://pcpartpicker.com/p/BwFdRB
Price breakdown by merchant: http://pcpartpicker.com/p/BwFdRB/by_merchant/
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($248.95 @ B&H)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($28.99 @ Amazon)
Motherboard: Asus Z170 PRO GAMING ATX LGA1151 Motherboard  ($162.99 @ Directron)
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR4-2133 Memory  ($45.99 @ Newegg)
Storage: Hitachi Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive  ($48.50 @ Amazon)
Video Card: Gigabyte Radeon R9 390 8GB SOC Video Card  ($327.99 @ NCIX US)
Case: Cooler Master HAF XB EVO ATX Desktop Case  ($86.99 @ Amazon)
Power Supply: Rosewill 1050W 80+ Gold Certified Fully-Modular ATX Power Supply  ($139.99 @ Newegg)
Total: $1090.39
Generated by PCPartPicker 2015-10-09 04:47 EDT-0400
Total: $1090.39
I was kinda thinking going with this:
PCPartPicker part list: http://pcpartpicker.com/p/CR3sGX
Price breakdown by merchant: http://pcpartpicker.com/p/CR3sGX/by_merchant/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($200.98 @ Newegg)
Motherboard: Gigabyte GA-H170-GAMING 3 ATX LGA1151 Motherboard  ($114.99 @ Newegg)
Memory: Corsair Vengeance LPX 8GB (2 x 4GB) DDR4-2400 Memory  ($57.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($52.33 @ OutletPC)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($318.99 @ SuperBiiz)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($49.00 @ Newegg)
Total: $939.26
Generated by PCPartPicker 2015-10-10 03:51 EDT-0400
Get less expensive RAM
and get a 390 over a 970, for sure
Are there cheaper ddr4 ram modules?
Also, what are your thoughts on 380 crossfire? i was thinking about getting one for now, then adding down the line. Will it be a better fit?
Just get the 390, or maybe 380X if that drops soon
most likely 2133mhz RAM is going to be cheaper, RAM speed doesn't matter for much of anything
What about directX 12? is this supported at all?
That would be another reason to go AMD
