Hello,
I recently purchase a roccat tyon mouse and for some reason every so often the mouse would hit a invisible wall of sorts were as I am moving my mouse the cursor would not be able to continue in that direction for a short while. This is not a long lasting issue as the way i fix it is to move the mouse around for a bit but it is a reoccurring issue. This can be incredibly annoying when I am playing a video game so any response would be much appreciated.
Thanks.
https://linustechtips.com/topic/463388-mouse-hitting-a-invisible-wall/
Yes and there is no problem on a new comp.
I tried switching usb ports but im not sure if that worked yet because this problem is pretty random in terms of when it occurs.
Maybe try removing and reinstalling the driver?
Intel Core i7-6700k | 2 X Gigabyte 4GB GTX 970 Overclocked Edition | 16GB (4X4GB) DDR4 2133MHz Corsair Dominator Platinum | MasterCase Pro 5
ASUS Z170 Deluxe Motherboard | 256GB Samsung 840 Pro + Seagate 2TB Storage | Corsair Hydro H80i GT | Windows 10 Pro 64bit | Corsair HX850i
So far after changing usb ports its bin fine but I will have to see in the long run if this is a permanent solution.
Oddly enough that has happened to me and changing the USB port works. And then others its only a solution for a while.
I had a mouse that did some weird things like you explained. I ended up finding out that the mouse was faulty later after the problems got worse. New mouse, no problems.
No problem! Be sure to report back and mark as solved if you do not need more help on the issue later!
