Can someone please help me revise this list before purchases? Going to be used for everyday use along with gaming. A 1440p monitor will be in use with this build. Thanks in advance.
Motherboard: MSI H170 Gaming M3 ATX LGA1151 Motherboard  ($119.99 @ Amazon)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($328.99 @ SuperBiiz)
Total: $1047.15
Generated by PCPartPicker 2015-10-07 21:16 EDT-0400
~~ Intel Xeon E5-2696 v4, Asus X99-A II, Adata 2x8 GB, EVGA GTX 980Ti FTW, InWin 303, Dell U3415W~~
https://linustechtips.com/topic/463376-help-revise/
Total: $1047.15
looks fine..tho I would get a 250gb ssd
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/463376-help-revise/#findComment-6219081
R9 390 instead of 970, unless power consumption is a big issue for you
I would agree, but they would also have to upgrade their PSU to a 650W.
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
https://linustechtips.com/topic/463376-help-revise/#findComment-6219099
Looks good, but you could always go for a Z97 build and use the savings on a better GPU if this PC is pretty much only for gaming.
My Rigs:
Gaming/CAD/Rendering Rig
Case:
 Corsair Air 240 , CPU: i7-4790K, Mobo: ASUS Gryphon Z97 mATX,  GPU: Gigabyte G1 Gaming GTX 970, RAM: G.Skill Sniper 16GB, SSD: SAMSUNG 1TB 840 EVO, Cooling: Corsair H80i PCPP: https://au.pcpartpicker.com/b/f2TH99SFF HTPC
Case:
Silverstone ML06B, CPU: Pentium G3258, Mobo: Gigabyte GA-H97N-WiFi, RAM: G.Skill 4GB, SSD: Kingston SSDNow 120GB PCPP: https://au.pcpartpicker.com/b/JmZ8TW
https://linustechtips.com/topic/463376-help-revise/#findComment-6219141
Yeah. Power is ONE issue if I do that. Another issue is, the Nvidia Shadowplay is something that I need. Not looking to spend another few years with AMD's DVR program. I've dealt with their DVR program for over 2 years now and it has frustrated me every single time I've used it. Definitely would go with the 390 tho. If only AMD had better recording software...
https://linustechtips.com/topic/463376-help-revise/#findComment-6219161
Stick with nvdida :) we have cookies.. ANYWAY looks good to me. I'd get a 256gb ssd though as the 120 will fill up instantly.
TX10 Build Log: http://linustechtips.com/main/topic/456229-tx10-build-log/
Case: TX10-D   Proccessor: i7-5820k   MotherBoard: Asrockx99 Extreme4   Ram: Crucial Ballistix Sport 16GB (DDR4-2400)   GPU: Asus Strix OC 980ti   Storage: 850pro 500gb, 850pro 500gb, 850pro 256gb, WD black 16tb total, Silicon Power S60 120GB   PSU: Seasonic snow silent 1050   Monitors: Three of Asus VG248QE 144Hz 24.0"
https://linustechtips.com/topic/463376-help-revise/#findComment-6219215
