FTP Server Help And Questions
Thanks for your post I managed to get the FTP server working, I solved the problem by using a different port other than 21.
Now I noticed in the logs for the server, whenever someone navigates to a different folder, it says "logging in" and then when they go to a different folder it says "disconnected" then "logging in" again. Is this normal?
Also, I asked him and it says that the server is fine, except when trying to stream a video through VLC the video loads the first 2 seconds then stops working.
That is normal for that to occur, especially if the user is sitting idle for a while. The reason they might not have been able to connect over port 21 is that sometimes ISPs block common ports like that for your protection (although it is weird that the tests you ran worked if that was the case), and the fact that you're generally not supposed to be running servers off of residential connections.
As for the video problem, what is your upload speed and his download speed?
Nice Keyboard btw
