CPU OC help
Go to solution Solved by JustCallMeVlad,
Manual Voltage
45X Multi
1,30v voltage
Save and reboot. Test for Stability
Manual Voltage
45X Multi
1,30v voltage
Core I7 5960X / Gigabyte X99 SOC Force / Kingston 16GB DDR4 3000 / EVGA GTX 980 Classified's In Quad SLI / EVGA 1600W G2
Core I7 6700K / Asus Z170 Maximus VIII Hero / Corsair 16GB DDR4 3000 / MSI R9 290X Lightning / EVGA 1600W T2
https://linustechtips.com/topic/462674-cpu-oc-help/#findComment-6209329
Hi! i got a i7-2600k sandy bridge and i wanna OC it.
i have kraken x41 installed on it so temp wont be problem.
What program should i use to stress test it?
should i use auto or manual when controlling voltage?
Put voltages on manual when OCing.
Use Prime 95 / Aida64 / Intel XTU, as well as the programs / games that you normally use. That should give you a great indication on stability.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/462674-cpu-oc-help/#findComment-6209401
