need help with psu
Solved by STRMfrmXMN,
Is OCP important? the m12 evo don't have OCP while the G 550 has.
what is important the watts under the 12v or the total output? http://www.seasonicusa.com/images/M12-EVO-Edition/M12-EVO-Edition-04-520.jpg
and last is 520 or 550 watts enough for a OCed 4670k @ 4.0 ghz on 1.2v, gtx 970 strix?
TIA.
Not sure, a bit tired right now so I'm having a hard time reading your post... sorry...
Watts on 12V rail is more important as that's the max output it can actually put out.
Both are plenty of wattage for that system.
