I put one of my SD cards inside a Ziploc bag and I was wondering if ESD from the bag would have harmed the card?
As beeing a removeable device, it is allways threatened by ESD, so it has a strong build in protection.
You are fine.
Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil
https://linustechtips.com/topic/462625-sd-card-and-esd/#findComment-6208511
It's working fine as far as i can tell.
Then why would it have harmed the card :P
no a ziplock bag should not harm the card in anyway, lots of people carry cards that way, but you should invest in a card wallet / carry case, they are cheap and worth it
https://linustechtips.com/topic/462625-sd-card-and-esd/#findComment-6221019
Yeah I doubt a bag would kill it as SD cards have been known to be found in the ocean or ran though washing machines and still work. I grabbed one of these at a London drugs for like 5$ or something. Way better than keeping them loose or in a bag.KS3LisM.jpg
Main PC CPU: Intel i7 2600k 3.2Ghz RAM: Corsair XMS3 16gb Video Card: Gigabyte N970IXOC-4GD Motherboard: Asus Sabertooth P67 PSU: Coolermaster Silent Pro 850W Laptop: Acer VN7-591G-787J
Camera: Canon 70d, Sony NEX F3 and a Go Pro Hero 2. Lenses: Canon 18-135EFS F3.5-5.6, Canon 50mm F1.8, Sigma 70-300 F4-5.6, Sony 18-55 F3.5-5.6. Audio: Zoom H1, Neewer Shotgun.  I do a bunch of stuff! Games: SplitScreen (YT) Civvie00 (Twitch) Tech: Civvie (YT) Other Stuff: Civvietv (NicoNico)
https://linustechtips.com/topic/462625-sd-card-and-esd/#findComment-6221464
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/462625-sd-card-and-esd/#findComment-6221696
