Laptop help
Go to solution Solved by Castdeath97,
I don't NEED max graphics as long as I have playable framerate
Unfortunatly my local retailer doesn't sell the GE60. They do however sell the GP62. Would this be a solid alternative?
Yes, just try to look for the ones with the 950, as the difference between a 950 and a 940 is too big.
(The 850 is fine too)
Looking for a solid mobile laptop.
I'd use it mostly for schoolwork and light gaming.
The heaviest game i'd play would be Payday 2.
I was just wondering what would be the cheapest solution.
I don't mind spending a little more for comfort things like a backlit keyboard.
Thanks in advance!
(Sorry for my bad English)
https://linustechtips.com/topic/462504-laptop-help/
lenovo y40 if you can get it.
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/462504-laptop-help/#findComment-6206793
I'd prefer to get a laptop from a brand that I trust like MSI or Asus.
MSI leopard GE60.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/462504-laptop-help/#findComment-6206810
Is it enough to run Payday 2?
Depends on which settings you are comfortable with.
https://linustechtips.com/topic/462504-laptop-help/#findComment-6206884
https://linustechtips.com/topic/462504-laptop-help/#findComment-6207128
