MT/s = MHz?
Solved by Glenwing,
Yes. Megatransfers is the actual unit for those numbers, not MHz.
You'll notice memory is not listed as "2133 MHz", usually it's just "DDR3 2133". That is because it doesn't actually operate at 2133 MHz, it operates at 1066.6 MHz, but because it's DDR it does two operations per cycle, so it's as if it were 2133 MHz, but it technically isn't. So the proper unit to use would be 2133 MT/s which is the actual number of transfer operations that occur rather than the frequency, since those are no longer the same number with DDR memory. So you can think of "MT/s" as basically "effective MHz".
