Help with high temperatures with h105
Solved by QBtech,
Pull out the fans, and put the pump in pwm1.The corsair logo lights up when I turn the power on, but I do not hear any significant noise coming from it.
Set pwm1 to full power. If no pwm signal nor any sound from the pump at all put the pc off and rma that h105.
All aio pumps make atleast a little sound. If it is not audible at all its not working. Stick your ear next to it if you have to
----Edit----
You can also feel the pump work if you put your finger on it.
Btw if you have any way of delivering power without turning the pc on that would be preferable
