CableMod Replacement Kits?
Solved by quan289,
1) You can only used the "C-Series" cables from Cablemods. This is because the connector on the PSU tend to be made so it cannot be used with other brands (sometime even across different series within a brand); ; otherwise, the cable set wouldn't be grouped up in such a way.
2) CableMod has a "Basic set" that has only the 24 pin, 4+4 pin EPS12V/ATX12v, and two 6+2 pin PEG connectors. http://cablemod.com/product/cablemod-c-series-rmi-rmx-basic-cable-kit-black-green/
