My ram is 1866mhz 9-9-9-24. However on my BIOS is default 1600mhz 11-11-11-34. I try making it what it's running at, changed all timings and MHz, volted to 1.65 and 1.5v. When I'm running benchmarks like valley and 3d firestrike, it's fine no crashes or freezes. Problem is when I get into games after a few seconds it auto closes with no error or anything. Works fine with 1600mhz 11-11-11-34. Help pls
CPU: Intel i7 8700k || Motherboard: Asus Z370-E ROG || RAMCorsair 4266 2x8gb || GPU: Sapphire r9 280x tri-x || Case: Corsair 780t ||
Storage: Samsung 850 Evo 250GB, 1TB Segate Barracuda HDD || PSUSeasonic M12II Evo 850w || Display: AOC i2367FH 1920x1080p 23 Inch ||
CPU Cooler: Corsair h80 || KeyboardCorsair Strafe || MouseCorsair Scimitar || HeadsetHyper X Cloud II || OS: Windows 10 ||
https://linustechtips.com/topic/461547-ram-problem/
Have you tried using the XMP profile associated with the DIMMs?
https://linustechtips.com/topic/461547-ram-problem/#findComment-6193202
Yes
https://linustechtips.com/topic/461547-ram-problem/#findComment-6193208
Yes
Does it occur in all games?
https://linustechtips.com/topic/461547-ram-problem/#findComment-6193226
Yea, titanfall,crysis3 witcher 3 guild wars 2,all closed itself
https://linustechtips.com/topic/461547-ram-problem/#findComment-6193231
many of the gskill 1866mhz kits seemed to be rated at
1866mhz  9-10-9-28 2N  1.5V
I would try the above settings with up to 1.65V
can you link your exact memory kit?
Mainboard Asrock Z170 OCF CPU 6700k RAM Tridentz 3600 HDD Intel 730 240gb GPU GTX 780ti sc acx PSU Silverstone Strider 1200W  Case Antec 900 Laptop Lenovo Thinkpad T520 build log-   http://linustechtips.com/main/topic/35809-antec-900-the-re-birth-of-a-legend/ Check out the Tech Center https://www.youtube.com/user/prokon24/videos LTT's Unicore King
https://linustechtips.com/topic/461547-ram-problem/#findComment-6193248
First you need to understand that bench testing is just that, its a bench test and normally gives you a best case scenario when testing.
I know this isnt the answer your looking for, however Im going to give it to you in any case. The performance increase you will get from changing the timing and mhz is so small that I would be asking myself the question, "Is it really worth it."
https://linustechtips.com/topic/461547-ram-problem/#findComment-6193282
