Help with processor generation
Solved by Kherm,
Hey guys
So I want to know if this processor (intel core i3-4150) and this motherboard (Asus h81m-k) are compatible because the motherboard says it is made for a 4th generation intel processor but my problem is that i can't figure out what generation this processor is from. And say that if the cpu isn't from the 4th generation would I still be able to use it with my motherboard or not ?
Thanks in advance.
Yes. The '4' in 4150 means 4th gen.
From now on, you should use pcpartpickler.com to sort out products and see if they're compatible.
