Hi
Was about to buy a Thermaltake Urban SD1 case but discovered the Lian-Li PC-V358 but unsure if its better (I know it costs a fair deal more)?
Review states it supports "half-height 240mm radiator (dual 120mm fan)" does it have to be 240mm or can it be used with a 120mm radiator such as that on a AMD Fury X (is the Fury X radiator even half height)?
I don't think the PSU has any ventilation would that be a problem? The Thermaltake case has vents on top which I think is the position the PSU fan would go in that situation.
Thanks
https://linustechtips.com/topic/461334-lian-li-pc-v358/
The Thermaltake one, from my research, doesn't fit a psu? From my experience though, thermaltake has been plastic and was never reliable. I can see you are going for a smaller case, but I would recommend the Lian. I currently have the NZXT h440 but that's bigger.
https://linustechtips.com/topic/461334-lian-li-pc-v358/#findComment-6190411
What do you mean? Of course it supports a PSU how else would it have power to switch on and operate
https://linustechtips.com/topic/461334-lian-li-pc-v358/#findComment-6190450
