How come my brother is able to play HD youtube videos on his ipad without buffering while it takes me forever to load a video on my computer when I do it at the same time?  Is there a way to make my computer a higher priority on the router?  Would be nice if I didn't get 300 ping in CS:GO when he's watching youtube videos at the same time.
I use a LAN cable btw.  Though I don't use it all the time since it barely reaches my computer.
https://linustechtips.com/topic/460685-bandwidth-traffic-control/
There can be such a feature to limit the bandwidth to particular devices but its a router by router thing.
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
For that you would need to set up some QoS :) most consumer or ISP routers cant do advanced stuff - so the easiest way would be to limit your wifi speed if possible on the network that your brother connects to :D
Might also be your MTU that is set wrong on your router - if you have your own router connected to your ISPs modem/router, you need to research the settings yourself - if you are using a router supplied by your ISP, try calling them and have them check its settings in this regard. :)
