Hi guys.
My bro is building a pc and is using NVIDIA for his gpu. EVGA ACX 2.0 GTX 980 to be exact. He's using a 4790k with the hyper 103 as his CPU cooler. My only question is should he use more than 2 fans? Obviously it would be nice to have 3 or 4 fans but is 2 fans ok?? Its not like he's using an AMD card which supposedly run very hot.
Suggestions/opinions??
https://linustechtips.com/topic/460619-fans-in-a-case/
One for exhaust and one for intake should be fine. Everything might be a little warm under load but it shouldn't be a problem.
FX-6300 cooled by Nepton 240M | EVGA GTX 970 SuperClocked | 8GB G.Skill ValueRAM | Cooler Master 690 III | Sharkoon WMP 500 Bronze
Power supplies:
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/ My F@h stats: http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=zyntaxable Intel vs. FX for gaming: http://linustechtips.com/main/topic/401217-more-updated-fx-vs-intel-for-gaming/
https://linustechtips.com/topic/460619-fans-in-a-case/#findComment-6181739
Hi guys.
what are the rest of his specs please?
one intake and one exhaust is good.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/460619-fans-in-a-case/#findComment-6181740
As long as the airflow is controlled and you don't two fans competing causing dead spots where hot air pools, the increased airflow throughput is never usually a negative.
Check the temperatures, if everything runs nice and cool without too much noise then it's all good. He may wish to add more fans and have them all run at a lower RPM if he wants a quieter rig with more cooling headroom. But honestly it's entirely dependent on his current temperatures.
Platform agnostic software engineer & small business owner.
https://linustechtips.com/topic/460619-fans-in-a-case/#findComment-6181744
