So i followed this guide
http://forum.xda-developers.com/shield-tablet/development/root-root-nvidia-shield-tablet-lollipop-t2972316
But i ran into a problem
When the guide says "recovery reboot" i have two options:
"Recovery mode" and "reboot"
Which one should i choose?
Please help me as fast as you can
Long live Stalin, he loves you; sing these words, or you know what he’ll do!
https://linustechtips.com/topic/459093-please-help-android-root-problem/
Now I'm aware the post says "NVIDIA Shield" but it'd probably help if you told us more about your device / setup in the future.
I'm fairly sure it wants you to select "Recovery mode", but no harm should be done if you were to select the wrong one. Just hard reset the device if it doesn't boot into CWM. If you want to be actually sure about what you're doing, though, you could just post in the XDA thread...
recovery mode, since that'll get you to your CWM most probbaly
You have to reboot into recovery,switch off the phone,when its off,hold power button and down volume and your custom recovery will show up,then flash the superuser zip
After trying to flash it, i get this, if noone knows how to fix it its fine though, will probably do as jade said and post on XDA
I solved this before by reconnecting the device, although im not sure if im allowed to do that here
You have to put the device on sideload mode,its in recovery,the option is called update through adb
I was in sideload mode though
