-snip-
Well ive had a note 4 in the past and i can say that as far as connection problems go it could mostly be the wifi hub/router instability due to overusage from other wirelessly connected devices or because in the area you where currently something could be blocking part of the incoming signal. Some phones have better connectivity than others but it doesnt mean theyll be able to sustain the same bandwidth or even link at all times without small gaps.
Groomlake Authority
Well, when i reboot the phones, it works again :D
