LTT login issue
Go to solution Solved by the pokemon kid,
Okay, solved it. It was the LTT notifier extension for Chrome. When it would pop up in the taskbar it would also kick me out. I didnt notice because I was raging at getting kicked out and having to start writing the post. I also put it down to getting logged out from the site and not the notifier kicking me out.
I deleted it and reinstalled the extension and it is now working fine!
Hi Guys,
I have been having an issue with the website since the data breach and we were asked to change our passwords.
The website is constantly kicking me out. After about a minute I am kicked out of the website and have to log back in again. Its getting kinda annoying now.
I have cleared all caches. I have deleted my LTT password from Chrome on all PC's. Yet I am still having the issues...
Is this happening to everyone else or is there a way around this!
Cheers,
TPK
https://linustechtips.com/topic/459061-ltt-login-issue/
I have no issues, I'm assuming you changed your password from the temp one they gave us so I'm unsure why this is happening try changing you password again
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
https://linustechtips.com/topic/459061-ltt-login-issue/#findComment-6160275
Hi Guys,
Cheers,
TPK
dude just change your password.
https://linustechtips.com/topic/459061-ltt-login-issue/#findComment-6160276
Already have done. Changed it from the temp one the gave in the email...
https://linustechtips.com/topic/459061-ltt-login-issue/#findComment-6160290
https://linustechtips.com/topic/459061-ltt-login-issue/#findComment-6160935
