Right now, on Newegg, there is a "PowerColor PCS+ Radeon R7 370 AXR7 370 4GB" for $134. Should I get that, or a Gtx 950? I don't fully understand the AMD graphics card lineup at the moment and this card looks sketchy to me for some reason. I have to leave soon, so I will look at the answers when I get home. Thanks!
https://linustechtips.com/topic/458952-need-help-deciding-on-graphics-card/
r7 370
Join da discord
(Intel Core i5 4590 - XFX R9 280 - ASUS z97-A USB 3.1 - EVGA SuperNOVA 750B - 16GB EVGA DDR3-EDITION - NZXT H440 -
WD BLACK 1TB - OZC ARC 100 240gb)
#locked(ง ͠° ͟ل͜ ͡°)ง
i would get a r7 370
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
I actually own a R7 370 exceot mine is MSI's version, and to me the MSI R7 370 4GB is good for the 180 I paid, Im gunna have to say that the Powercolor edition you're looking shoulden't be too far from the same performance. I know the GTX 950 beats the 2GB version of the R7 370, For a little bit extra cash though, id go doe the GTX 960 to get that 4GB of VRAM if you're looking into some mid-high gaming.
to be honest if i were going to buy a card in the $130 price range i would go with the ASUS GeForce GTX 750 Ti  STRIX or the EVGA GeForce GTX 750 Ti
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121896
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487028
or
for another $30 - $40 the gtx 950 versions of both thoughs cards
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121980
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487157
No Excuses, Play Like A Champion!!!
or
The R7 370 or the 950 are way better than the 750ti, there is no point to considere the 750
yes, i was just trying to find good cards in the 130$ price range... but thats why i included the $160 - $170 gtx 950s because they are worth it
or
Thanks for the advise, I'm going to go with the PowerColor PCS+ Radeon R7 370 AXR7 370 4GB
