I have been having trouble finding keycaps for the CM storm quickfire rapid keyboard to replace the ugly font, and I thought I could utilize the forum.
Here are the required specs
Cherry MX stem
ANSI
Lets Backlight through
All black and a basic font
http://pcpartpicker.com/part/cooler-master-keyboard-sgk4000gkcl1us
Thanks!
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
https://linustechtips.com/topic/458682-help-me-find-some-keycaps/
With these keycaps, you get the quality of PBT and the ability for backlighting as well.
https://www.massdrop.com/buy/vortex-backlit-doubleshot-pbt-keycaps
Do you prefer ABS or PBT?
I owned the white version of those caps. They are pretty decent, although the pbt is strangely smooth compared to other pbt and the backlight bleed is pretty bad... Also, they are thin-walled.
Hey! New SIgnature!
I'm supposedly a person on the Internet, but you'll never know if I'm human or not ;)
