PC won't POST, used USB Flashback, still receiving power, but turns off immediately
Solved by Litargirio,
Unplug all of the PSU cables and grab the 24-pin motherboard cable. Using a clip or a wire, short the green with any of the black wires.
If the wires are all black, calculate where the green wire would be using this image. Look at the plastic clip in the middle, and make sure you don't short the wrong cable, or you'll blow the PSU up!
Do that and check if the unit stays on. If it does, don't leave it on for too long. If it doesn't, it's faulty.
