hi LTT,
looking to downsize my oldie rig to a m-atx/itx, as i want a smaller rig so it won't take up much space. playing dota 2 & some old titles mainly nowadays, will it bottleneck in the future if i were to upgrade to a gtx 970~980TI to play more future titles ? currently using a 1080p monitor, in the future maybe 1440p/4k. the 4 components are pretty much what i need only. lastly, is it worth to downsize the rig as i'll probably upgrade my gpu & monitor in not a very near future ?
location - singapore
budget - 700 usd
parts i'm looking to re-use
- evga gtx 750ti s.c
- 2x4gb 16000mhz corsair vengence ram
- 250gb evo ssd
- 500gb black wd hdd
- 520watt 80+ bronze seasonic psu
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.99 @ SuperBiiz)
CPU Cooler: Corsair H100i GTX 70.7 CFM Liquid CPU Cooler  ($109.99 @ Amazon)
Total: $542.96
Generated by PCPartPicker 2015-09-29 12:01 EDT-0400
I ended up downsizing my cooler master cosmos rig into an mATX rig with the same amount of cooling simply by buying a smaller motherboard.
 an i5 3570 + asrock z77 extremem 4 mobo
Unless you'd like to overclock that's still fine for gaming (and you'd only need to buy a new cooler if wanted, smaller mobo and case :P)
USEFUL LINKS:
PSU Tier List F@H stats
the z77 can manage 3.8ghz on a locked 3.3ghz sandy bridge. not sure about ivy bridge
If you do choose to go to 4k on a small form factor, there is only one option:
sorry NVidia fanboys, im talking about the R9 Nano
EDIT: for the future, for that budget 750ti is fine
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
hi LTT,
budget - 700 usd
- 250gb evo ssd
Total: $542.96
get a better CPU or GPU and dont do the watercooler, watercooling is only worth it when you have an i7 and a 980 Ti/fury x   :D
fury x is better tho :D
for ITX? i think not
Solitaire.
watercooler bro...
its still like 3" longer
if you can make it fit and dont mind the 100W extra TDP, go for it, but the Nano is almost exactly the same performance, is 3" shorter and 100W less TDP
Solitaire.
its the same price and less performance...
image no work for me
Solitaire.
thanks guys for the advise/input so far
i think the 4690k (will do abit of oc) is good enough for gaming, p.s, since the budget is there, i'll stick with the h100i  :lol:
im cooling my 4690k on a 212 evo and im at 4.5 and i peak at 60c, which for $25 is gr8
Solitaire.
do you already own the i5-4690k?
