DISK AT 100% HELP!
Go to solution Solved by don_svetlio,
This is Windows 8.1/10 - it does that (scanning, defragmenting, spying) occasionally for a few minutes and stops. Perfectly normal
Hi! Here's a snippet of my task manager: post-218513-0-68233300-1443450114.png It has happened before and makes my laptop really slow :( As I'm writing this, the disk usage is very erratic and is going up and down from 20% to 100%. It has now stopped tho :) This problem doesn't occur when I'm in a different account (where almost everything is disabled.) As for this incident, it occurred when I had logged in into my personal account. Maybe its because its reading all the things enabled for startup? Any thoughts on why it is doing so?
i5 4590 | Sapphire R9 380 Nitro | MSi H97 Gaming 3 | 8GB HyperX Fury 1600MHz | 1TB WD Blue | ADATA SP900 128GB | Seasonic M12II 620W | NZXT. S340 (Black & Red) |
https://linustechtips.com/topic/457779-disk-at-100-help/
https://linustechtips.com/topic/457779-disk-at-100-help/#findComment-6142910
oh ok. Thank you :D
https://linustechtips.com/topic/457779-disk-at-100-help/#findComment-6142917
It's Windows Update being Windows Update. Let it do its thing.
ah, I see. Ok thanks ;)
https://linustechtips.com/topic/457779-disk-at-100-help/#findComment-6142923
I have the same problem with my laptop, it takes 10 minutes to boot up, 5 minutes to turn on chrome after booting. It's probably broken. The speeds also couldn't exceed 3 mb/s copying files. And I have i5 4200U and GT750M GPU on that laptop which isn't the cheapest one out there.
https://linustechtips.com/topic/457779-disk-at-100-help/#findComment-6142936
wow. weird. Send it in for repair :/
https://linustechtips.com/topic/457779-disk-at-100-help/#findComment-6142944
if it doesn't stop its a rare windows OS error, ive had it before and it happens every time you boot up and crashes your OS,
oo wow. Thanks for the tip. How do I go about fixing the problem if it ever happens to me?
https://linustechtips.com/topic/457779-disk-at-100-help/#findComment-6142951
Theres a small chance just installing it again will fix, but if it does happen again, you need a new Drive or MOBO
https://linustechtips.com/topic/457779-disk-at-100-help/#findComment-6142960
that sucks. It'll probably never happen to me anyways...
https://linustechtips.com/topic/457779-disk-at-100-help/#findComment-6143032
