Going from AMD to NVidia help!
Go to solution Solved by don_svetlio,
use DDU to remove AMD drivers, then swap cards and you're done.
Hi y'all
Somewhere this week I will receive my new GPU (GTX 950) and I currently have an AMD (HD 6850).
What do I need to do to replace the old one for the new one, driver wise?
I would think I just take out the AMD, plug in the NVidia, remove AMD drivers and install NVidia drivers.
Will this work or do I need to do something else / in a different order?
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
https://linustechtips.com/topic/457418-going-from-amd-to-nvidia-help/
You can remove amd drivers before putting the 950 in and download the nvidia drivers as well, then just plug in the 950, turn on the PC and click on the installer.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
  1. Download and run Display Driver Uninstaller on your current HD 6850 system.
Once you run this software, remove your HD 6850 and install your GTX 950
Download and install latest GeForce Drivers
Done!
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
Remove the drivers but use something like @don_svetlio suggusted to wipe old drivers or there may be issues. I suffered from bluescreen after an Nvidia to AMD switch until I used driversweeper and re-did the drivers properly.
Any reason why I should use DDU instead of removing them manually?
My System:
Nvidia is an ass about it - that's why. If AMD drivers or leftovers are present Nvidia stuff refuses to work. It also screws with the AMD stuff.
Okay thanks.
And thanks to all of you :D
My System:
- uninstall amd driver (theres utils for this, you dont have to use them, but you can to be sure, it performs a "cleaner" uninstall.)
- turn off system (use the rocker switch on your psu as well if you have one)
- unplug old GPU
- plug in new GPU
- power on system
- install nvidia driver
- reboot.
- profit.
