I got my first PC from a build site, because I wanted the warranty and to know it would work.
Had said PC for a couple of years and am upgrading: GTX 980, Intel 6600K, Asus Z170 PRO Gaming Motherboard, 16GB DDR4 and a new case, the only things I'm keeping are the PSU and Hard drives.
The thing I need to know is can i just plug the hard drives into the new PC or will i need to clear them off and start from scratch?
https://linustechtips.com/topic/457342-first-pc-build-help-needed/
Just checked its the VS 550
Definitely would replace. PSU is one of the most important parts of your PC if that goes out it could take out the whole system along with it so you want to make sure to have a good quality PSU that can handle high components, higher temps and load, good quality capacitors and safety measures in place if anything was to happen
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
I have an i3 right now, would i need the drivers before I move it over or when its in the new pc?
I would remove the current drivers from the storage, then boot the new rig. It should recognize the operating system and boot up fine.
Example. I got fancy with my overclock and messed up so bad I had to switch bios. For all intense and purposes I had a new motherboard. It booted like normal after I set the boot sequence in the bios.
If anyone asks you never saw me.
Here is the cheapest I could get on Amazon for a decent Rig (Micro ATX):
CPU: AMD FX-6300 6-core Black Edition ($99.99) Link: http://www.amazon.co...ements=p_89:AMD
MotherBoard: MSI Micro-ATX DDR3 1333 A68HM Grenade ($62.77) Link: http://www.amazon.co...1,p_89:Asus|MSI
Memory: Kingston HyperX Fury 8GB (2x4GB) DDR3 1600MHz ($84.43) Link: http://www.amazon.co...0R34BSKRS15ST4G
Storage SSD: Kingston 120GB Sata 3.0 2.5" v300 ($50.44) Link: http://www.amazon.co...8011|6797519011
Storage HDD: Western Digital Blue 1TB 3.5" 7200 RPM 6GB/s ($52.99) Link: http://www.amazon.co...-bin:8067150011
Video/Graphics Card: Asus Radeon R7-260x 2GB-GDDR5 ($129.99) Link: http://www.amazon.co...81011,p_89:Asus
Case: Rosewill Black SECC Steel USB 3.0 Mid Tower REDBONE U3 ($49.99) Link: http://www.amazon.co...d=ATVPDKIKX0DER
Power Supply:  Corsair CX 430W 80+ Bronze ($48.77) Link: http://www.amazon.co...-bin:6906983011
DVD/CD Drive: Asus DVD Sata Supermulti Burner OEM ($21.99) Link: http://www.amazon.co...type:2224371011
OS: Windows 7 Home Premium 64-bit ($89.00) Link: http://www.amazon.co...dows 7 software
Monitor: Asus VS207D-P 19.5" 1600x900 VGA LED ($85.99) Link: http://www.amazon.co...2796009&sr=1-19
Keyboard/Mouse: AmazonBasics Wired Mouse and Keyboard Combo ($14.99) Link: http://www.amazon.co...2796283&sr=1-44
Sound: AmazonBasics AC Powered Speakers ($19.99) Link: http://www.amazon.co...d=ATVPDKIKX0DER
Total:
$747.90 for everything
$632.93 for everything except the peripherals
$543.93 for everything except the peripherals and OS
Genesis 2:1|CPU- FX8320E|GPU- Asus R7 250X 2gb|RAM- 16GB Team DDR3 1866mhz|MOBO- Asus Sabertooth 990FX|HDD- WD 1TB|SSD- SD 240GB|PSU- 620w|OS-Win764HP|
Laptops:|Dell Latitude E6320 - CPU: i5-2520M - RAM: 6GB - HDD: 500GB - OS: Win 7 64U|Dell Inspiron 1525 - CPU: Celeron 540 - RAM: 1GB - HDD: 80GB - OS Win 7 32HP|
Total:
I already have the new Parts its just the questions I need not specs.
I would do complete reinstall to OS drive. You can keep personal files and most game installs on backup drive and just remap locations for them. But going from one mobo to another can be anything from easy switch to BSOD and fresh install needed.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
