Zombies lan party
Go to solution Solved by KingKeith55,
Why not just get WaW and do that, you can copy it over with WaW and it will work for Lan.
Besides it has modded maps.
They need there own copy of BO3
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/456219-zombies-lan-party/#findComment-6122531
What is the difference with copying bo3?
BO3 has more anti piracy measures. So you can't just do that as far as I know. Unless im wrong.
Also for WaW you need to download a patched .exe file for it, and that's all you need to do in order to get it to work from copying it over.
Honestly you will have a lot more fun just playing WaW, you can also download a crap ton of modded maps. And it can run on a potato computer.
https://linustechtips.com/topic/456219-zombies-lan-party/#findComment-6148818
