Hi I am building my first PC and it's time to pick GPU and I need someone's help.
I am playing in games like : GTA V, CoD, Witcher 3 Etc.
I play in 1080p.
I would like to have least 60 FPS at maxed settings.
My budget up to 600$ (Can go a little bit higher)
https://linustechtips.com/topic/456004-i-need-help-with-picking-gpu/
didnt we answer you already?
Either Fury air cooled Tri-X
or the 390X
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
you just asked this didn't you.
980ti > Fury (non-X) >= 980 = 390X
whatever you can in that order
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
I play in 1080p.
Follow your topics so you get notifications. Top right of the page, under the search box.
PCPartPicker link: http://pcpartpicker.com/p/R6GTGX
Привет товарищ ))))
a 980ti will only be a bit higher than $600, but perform better than a fury X while using less power, making less noise, and overclocking much more
Sorry I am new here so I still do not know how to use this forum SORRY :(
All is good, everyone started out where u
You are... and like said above, find a way to spend a little more and get a 980ti for 650, youll be MUCH better off. Or go on your local Craigslist and get a 980ti for 600, im sure there are a few out there
