The PC is in a college dorm room. I have set a Windows log-on password but my roommates can get around that so I need something more drastic.
Later edit: Forgot to mention that I run Windows 7 64bit and I have a MSI Z77A-G43 board (if that matters).
Why not put a password on the BIOS?
The Phoenix | i7 3930K 4.6Ghz | Z79A-GD45 Plus | 2 x GTX 780 SLI | 16GB Corsair XMS3 1600Mhz | Two 240GB Samsung 840s | 1.5TB Western Digital Caviar Green HDD | Silverstone TJ07 | Full Custom Water Cooling Loop
Streaming PC/LAN Rig | i7 920 3Ghz | Biostar X58 T-Power | GTX 460 1024Mb | 8GB XMS3 1333Mhz | 120GB Corsair SSD | Avermedia Live gamer HD C985
Hy guys, I'm looking for some way for my pc to not boot up unless it has a particular usb stick plugged in. I know there is software that does this but I don't know what to search for.
Help a brother out.
laptop, desktop?
edit: oop, missed your second post.
that's what I thought at first, but with desktop.. just reset battery from board lol.
My Rigs (past and present)
My case has a locking side panel so they can't get to the guts of the PC. I have an admin password in the BIOS but that just prevents access to the BIOS, it doesn't affect windows booting.
Maybe I'm just not ready for PC's... should have stuck to consoles... Or I could take the power cable with me when I leave. It will work until they buy another one for 2euros.
Since you have a locking case,  a cheap way is to move the power button to inside the case.  My motherboard has a power button on the board, so I didn't bother putting in the power button header.
OR if your handy, attach the power switch to a Locking switch DPST  like this:
Also disable start up of anything other than your main hard drive (this way they can't just boot from usb and reset password).
Other bios dependent options:
Depending on motherboard, Bios might have option for password on boot. Another one to look for is setting a password on hard drive in bios also activates the encryption in the hard drive (but that depends on the hard drive)
