Monitor HELLLP
BEY_bOred
Hello,
I have the Benq XL2411Z Monitor and a GTX 980 GPU. The monitor can do 120/144hz. I just bought a mini displayport to DVI (http://www.amazon.co.uk/gp/product/B00LUJOAQA?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00) as the ports on the GPU are (check attachment) and the ports on my monitor are (check attachment) but i still cant get 120hz or 144hz.
Please help
Thanks
post-139349-0-81848100-1443026267_thumb.
Isn't DVI incapable of greater than 60Hz?
EDIt: It is capable. I don't know then :/
Is it DVI-D only capable of above 60Hz? I remember something like that a long time ago, where DVI-D {with the full pin layout} would work. DVI-A {analog signal with about half of the pins} wouldn't work
but that's just a rumor
Thanks!
Chris R.
Hello,
Please help
Thanks
DisplayPort does not adapt to Dual-Link DVI. Only Single-Link DVI, which maxes out at 1080p 60Hz.
DVI-D will do 144hz but DVI-I won't.
That isn't true at all. If you don't use the VGA section of the port, a DVI-I port is completely identical to a DVI-D port.
I would make sure the adaptor supports the correct bandwidth?
Thanks for the quick response.
The only way i can get 120Hz is if i set the Resolution to 1024x768.
Have I bought the wrong cable. I don't think i can use DVI because on the monitor it is DVI-D(Dual Link), but on the GPU it is DVI-I(Dual Link), different pins on both ends.
Thanks again :)
Thanks again :)
Only Dual-Link DVI can go up to 1920x1080 144Hz, Single-Link can't. DVI-D vs DVI-I doesn't matter.
You will need a DVI-to-DVI cable. DisplayPort and HDMI both only adapt to Single-Link DVI.
Thanks again :)
Like Glenwing said, you have to use a dual-link DVI-D cable to get 144Hz on 1080p.
You could also use HDMI to get 120Hz at 1080p.
