So i've been doing a lot of research for the past month regarding my first gaming build and i've come up with this one.What do you guys think ?
Should i change anything ? (my monitor is 22 inch 1080p)
http://de.pcpartpicker.com/p/ngT3YJ
i haven't decided yet about the case fans but i am thinking 3 for AP front(intake) , 1 AP bot(intake) , 1 AP side(intake) , 1 AF back (exhaust) , 3 AF top ( exhaust)
Thanks !
https://linustechtips.com/topic/454892-my-first-gaming-build/
Probably a R9 390 instead of the 970
Everyday build:
CPU: Intel Core i7 5960x - GPU(s): 2x EVGA GTX 980 Ti Superclocked+ ACX2.0+ (SLI) - Cooler: be quiet! Dark Rock Pro 3 - Motherboard: ASUS Sabertooth X99 - RAM: 32GB Kingston HyperX Fury Black DDR4 4x8GB (2666MHz) - Storage: Intel 750 Series 1.2TB + 4TB WD Black - Case: Corsair 760T White - PSU: SeaSonic 1200W 80+ Platinum Certified - OS: Windows 10 Pro - Wireless Adapter: TP-Link Archer T9E - Monitor: Acer XB270HU bprz - Keyboard: Corsair K70 RGB - Mouse(s): Corsair Gaming M65 RGB + Logitech MX Master - Headphones: Sennheiser PC363D
http://pcpartpicker.com/p/WhyK99 https://linustechtips.com/main/topic/474247-r8-my-build/
Weekend build:
CPU: Intel Core i7 5930k - GPU(s): 2x EVGA GTX 980 Ti Classified ACX2.0+ (SLI) - Cooler: NZXT Kraken X61 - Motherboard: ASUS X99-Deluxe - RAM: 32GB Crucial Ballistix Sport LT DDR4 4x8GB (2666MHz) - Storage: Samsung 950 Pro 512GB m.2 & 2TB Samsung 850 Evo - Case: Phanteks Enthoo Evolv - PSU: SeaSonic SnowSilent 1050W 80+ Platinum Certified - OS: Windows 10 Home - Monitor: Dell S2716DG 144hz - Keyboard: Corsair STRAFE RGB - Mouse: Corsair Gaming M65 RGB - Headphones: Sennheiser PC363D
http://pcpartpicker.com/p/YYK93C
https://linustechtips.com/topic/454892-my-first-gaming-build/#findComment-6103143
Get the 390. It outperforms the 970 and has more vram.
CPU:Intel Core i3 3210 Mobo:MSI B75MA-E33  GPU:Intel 2500 HD Graphics  SSD:Adata SP600 128gb  HDD:Seagate 1tb 7200rpm
PSU:Corsair CX430   Case:Antec ASK4000bU3  Monitor:Dell S2240l 21.5 inch 1080p
https://linustechtips.com/topic/454892-my-first-gaming-build/#findComment-6103209
You could save a bit and just get an i5 4460, if you're just gaming it'll do fine
There's also some lower cost coolermaster cases that are nice.
https://linustechtips.com/topic/454892-my-first-gaming-build/#findComment-6103665
here i edit your list a little bit which is now a little bit better and cheaper
http://de.pcpartpicker.com/p/dJhJ3C
i also added a extra link below for case, and also you havent added any ram and hdd/ssd
http://de.pcpartpicker.com/part/corsair-case-cc9011051ww
https://linustechtips.com/topic/454892-my-first-gaming-build/#findComment-6106422
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  (€271.29 @ Mindfactory)
CPU Cooler: Phanteks PH-TC12DX_BK 68.5 CFM CPU Cooler  (€49.90 @ Caseking)
Motherboard: ASRock Z170 Pro4S ATX LGA1151 Motherboard  (€111.84 @ Mindfactory)
Memory: Kingston FURY 8GB (2 x 4GB) DDR4-2666 Memory  (€64.74 @ Mindfactory)
Video Card: MSI Radeon R9 390 8GB Video Card  (€350.90 @ Mindfactory)
Case: Fractal Design Define S ATX Mid Tower Case  (€80.66 @ Mindfactory)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  (€104.66 @ Amazon Deutschland)
Total: €1033.99
Generated by PCPartPicker 2015-09-23 19:50 CEST+0200
BigDay
https://linustechtips.com/topic/454892-my-first-gaming-build/#findComment-6106461
or this:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (€242.41 @ Amazon Deutschland)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  (€89.89 @ Amazon Deutschland)
Total: €918.42
Generated by PCPartPicker 2015-09-23 19:52 CEST+0200
BigDay
https://linustechtips.com/topic/454892-my-first-gaming-build/#findComment-6106476
  1. get a better cooling solution
  2. don't get the gigabyte board. won't let you set adaptive mode for your cache ratio and vring
  3. get an r9 390; performs better
  4. if you get the r9 390, get a 750w psu. 650w minimum
edit:
why don't you buy skylake?
I need a board that will be good for OC that's why i chose the gaming 5.
The 390 but which version ? (if i'm gonna pay 400euro for a card i need the best one on the market to last long till my next upgrade)
what is skylake ?
https://linustechtips.com/topic/454892-my-first-gaming-build/#findComment-6116845
what is skylake ?
Skylake is the latest Intel mainstream cpu. It replaced Haswell (Z97).
For AMD cards MSI and Sapphire are very good.
https://linustechtips.com/topic/454892-my-first-gaming-build/#findComment-6117165
what is skylake ?
if you get the 390, get the msi version. it's not voltage locked which means you can overclock it more effectively
BigDay
https://linustechtips.com/topic/454892-my-first-gaming-build/#findComment-6117588
