SO i just restarted my computer and it went into automatic repair mode. Help!!! no matter what i do, i just restored it, it won't boot into the OS. Please help, all help is appreciated!!!
https://linustechtips.com/topic/454798-help/
boot the windows cd
and do a repair on the boot sector
and maybe the file system
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/454798-help/#findComment-6101693
and if that doesn't work...boot a linux cd...backup your data...then do a repair install on the OS
...make sure you got all your data...then do a clean install of the os
https://linustechtips.com/topic/454798-help/#findComment-6101705
boot the windows cd
ok i just got an error 0xc0000225 what does that mean
https://linustechtips.com/topic/454798-help/#findComment-6101714
also i only have the windows 8.1 media, will that work on windows 10?
https://linustechtips.com/topic/454798-help/#findComment-6101731
no
you will have to download the 10 iso ...burn it to a usb stick..then use that
https://linustechtips.com/topic/454798-help/#findComment-6101737
no
ok where can i get the windows 10 iso without a key code
https://linustechtips.com/topic/454798-help/#findComment-6101743
the media create tool
OMG I JUST DID A SYSTEM RESTORE TO AN EARLIER DATE AND IT WORKED, THANK YOU SO MUCH
https://linustechtips.com/topic/454798-help/#findComment-6101779
