Hey guys, I need help building A gaming PC...
My cpu choice ( MUST HAVE ) is a AMD Fx-6300 6 core processor. Reason being its only 100$ and it gives the best performance money can buy sub 125$....
I don't know what else to pick because i've had no experience with PC'S at all.
But my must have is the Processor ( fx-6300 )
I need WIFI because my router is not close to my room.
The budget MUST NOT exceed the $500 mark.
https://linustechtips.com/topic/454767-need-help-with-stuff/
Fx processors suck bro get an intel
You cant build a gaming pc for $500 if you wanna play current games.
Reliable $550 Starter PC (http://pcpartpicker.com/p/KGgpZL) *Just waiting for someone to need help with there ram so I can make a downloadmoreram.com joke*
https://linustechtips.com/topic/454767-need-help-with-stuff/#findComment-6101198
CPU: Intel Core i3-4160 3.6GHz Dual-Core Processor  ($102.99 @ SuperBiiz)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($67.89 @ OutletPC)
Video Card: XFX Radeon R9 380 2GB Double Dissipation Video Card  ($193.98 @ Newegg)
Case: Thermaltake VL80001W2Z ATX Mid Tower Case  ($37.99 @ SuperBiiz)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($39.49 @ SuperBiiz)
Total: $533.72
Generated by PCPartPicker 2015-09-22 22:00 EDT-0400
https://linustechtips.com/topic/454767-need-help-with-stuff/#findComment-6101230
http://pcpartpicker.com/p/F6RdVn could use a stock cooler if you want to or for a little more: http://pcpartpicker.com/p/nfGDRB
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/454767-need-help-with-stuff/#findComment-6101247
Guys, Don't post rude comments or photos because I don't know anything about PC'S and I heard that amd processors are better because more cores and they are cheaper. If I ask for a certain thing please give a related post to it. I could care less what you think I should get.
https://linustechtips.com/topic/454767-need-help-with-stuff/#findComment-6101261
Have fun with the 6300...
Motherboard: Gigabyte GA-H81M-S1 Micro ATX LGA1150 Motherboard  ($41.99 @ SuperBiiz)
Memory: Team Elite 4GB (1 x 4GB) DDR3-1600 Memory  ($16.99 @ Newegg)
Video Card: Gigabyte Radeon R9 285 2GB WINDFORCE 2X Video Card  ($162.98 @ Newegg)
Power Supply: XFX TS 550W 80+ Gold Certified ATX Power Supply  ($44.99 @ NCIX US)
Total: $469.91
Generated by PCPartPicker 2015-09-22 22:02 EDT-0400
https://linustechtips.com/topic/454767-need-help-with-stuff/#findComment-6101265
Total: $533.72
That cant handle current games xD
https://linustechtips.com/topic/454767-need-help-with-stuff/#findComment-6101266
Coming from a FX-8320 owner, FX are completely pointless unless you have a real use like heavy rendering on a budget.
https://linustechtips.com/topic/454767-need-help-with-stuff/#findComment-6101278
If you don't want help why are you on here.
https://linustechtips.com/topic/454767-need-help-with-stuff/#findComment-6101304
Guys, If I where to go with an intel processor it would HAVE TO BE atleast an i5 quad core. Reason being I've heard alot of bad news about the i3's being not true quad cores even with hyper threading. The reason i go with the 6300 is because its cheaper and has 4+ cores. I just want a PC that can run games on normal settings around 30-45 fps, I'm not expecting to run games at 1440p or 4k at 60fps LMFAO. I just want a pc that has some upgradability later on. I know intel are better/stronger per core but i've yet to see any builds sub 550$ with i5 quad cores. Unless you can find one with %100 best performance then please don't suggest intel type builds. FX-6300 are my priority atm.
https://linustechtips.com/topic/454767-need-help-with-stuff/#findComment-6101312
Temp link: http://pcpartpicker.com/p/b39pP6
Edit: trying to fix format hold on
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($96.89 @ OutletPC)
Motherboard: MSI 970A-G43 ATX AM3+ Motherboard  ($59.89 @ OutletPC)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($41.89 @ OutletPC)
Video Card: EVGA GeForce GTX 750 Ti 2GB Superclocked Video Card  ($129.99 @ SuperBiiz)
Case: Corsair 300R ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($34.99 @ NCIX US)
Wireless Network Adapter: Gigabyte GC-WB867D-I 802.11a/b/g/n/ac PCI-Express x1 Wi-Fi Adapter  ($29.99 @ SuperBiiz)
Total: $491.41
Generated by PCPartPicker 2015-09-22 22:33 EDT-0400
https://linustechtips.com/topic/454767-need-help-with-stuff/#findComment-6101511
