I was wondering if my Corsair HX750 PSU is enough to handle my 2 GTX 980s in SLI? I also have an Intel Core i7-5820k. Also, will I have any room for overclocking? Thanks.
CPU: AMD Ryzen 7 5800X (liquid cooled) GPU: EVGA RTX 3080 Ultra non-LHR MOBO: Asus ROG Crosshair VIII Hero Wi-Fi RAM: 32GB G.Skill TridentZ RGB 3600MHz DDR4 (2x16GB) PSU: Corsair HX1200i (overkill yes, but was free!) Storage: 1 TB XPG SX8200 Pro NVMe, 2TB XPG SX8100 NVMe, 4TB WD Blue SATA SSD, 2x 480GB SATA SSDs, 3TB Seagate Barracuda 7200rpm Case: Corsair Obsidian 750D Airflow (with upgraded USB-C front panel) Sound Card: EVGA Nu Audio Liquid Cooling parts: EK Supremacy Classic RGB AMD Nickel+Plexi, EK-XRES 140 Revo D5 RGB PWM (incl. pump), 2x EK 240mm PE radiator, EK Duraclear clear tubing
https://linustechtips.com/topic/454738-build-help-pls/
You might not have a whole lot of room but you should have some. To be safe I'd go for like 800 watts.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
https://linustechtips.com/topic/454738-build-help-pls/#findComment-6100804
You know what, just hoped on PC Part Picker and 750 Watts should be fine, just be careful with your overclocking, if you start to get crashing scale it back.
https://linustechtips.com/topic/454738-build-help-pls/#findComment-6100824
Your fine. U will have room to OC unless u have 20 HDDs
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
https://linustechtips.com/topic/454738-build-help-pls/#findComment-6100838
I have the HX750 It's a rock solid PSU. But obviously be careful with water cooling / led madness or overclocking voltages. The headroom will be a little tight.
I am going to be watercooling my GPUs using my Swiftech H220-X and expanding it's loop. I am adding another 240mm radiator to it and will have the cards in a parallel config. The pump only uses 6W from what I read so I don't think it will be a problem.
https://linustechtips.com/topic/454738-build-help-pls/#findComment-6102469
You are safe to run two GTX 980's. And as for the room... You have a good quality power supply there so I personally wouldn't go and buy 800-850watts... Should be all fine.
https://linustechtips.com/topic/454738-build-help-pls/#findComment-6102494
you have "on the +12v"
62A
so... your psu is ready for sli and crossfire (not for oc they)
yea, i think all looks good and you be fine
still, for future builds friend
if you plan do a "top of the line" gpu x2
buy a 850w psu  ^_^
APU = A10
https://linustechtips.com/topic/454738-build-help-pls/#findComment-6103259
I went on eXtreme power supply calculator and did an advanced calculation of everything in my system. Apparently, my system draws around 606w. After calculating in the efficiency of my 80 plus gold PSU, I think i should be fine. Thanks everyone for your help :D
https://linustechtips.com/topic/454738-build-help-pls/#findComment-6120475
