So I recently got a 144hz 1440p monitor and playing gtav I get 80 fps but both my gpus have 50 percent usage and cpu is around 60 percent
Not sure why my cards aren't being pushed further to get higher fps
Any ideas?
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
https://linustechtips.com/topic/454558-low-gpu-usage/
What are thermals like in your system when playing?
gpus don't go over 75
also (1600)
https://linustechtips.com/topic/454558-low-gpu-usage/#findComment-6098294
make sure in the power settings its set to high performance.
and your GPU might just not be able to achieve higher FPS, no matter how much power is being used
also this is what 1440 GTA benchmarks look like
It is set to high,
Strange because when I add x8 msaa usage goes up at 90 percent on both and fps increases
So I don't no when when I lower setting I can't get 144 fps or 99 percent gpu usage
also (1600)
https://linustechtips.com/topic/454558-low-gpu-usage/#findComment-6098312
Whats wrong with 80fps lol
nothing but it's not the point
also (1600)
https://linustechtips.com/topic/454558-low-gpu-usage/#findComment-6098337
It is set to high,
I think you may just be maxing out the chips potential for Core speed, try overclocking it a bit by like 50MHz and see if you can hit higher FPS, if not somethings up.
https://linustechtips.com/topic/454558-low-gpu-usage/#findComment-6098363
Its very good that its low you don't want it higher because the more usage it has the more heat it generates which higher heats mean less life span.
Reliable $550 Starter PC (http://pcpartpicker.com/p/KGgpZL) *Just waiting for someone to need help with there ram so I can make a downloadmoreram.com joke*
https://linustechtips.com/topic/454558-low-gpu-usage/#findComment-6098369
Core speed clocks down as well it's so wired but if I push the resolution up via drs then usage and dos goes up
also (1600)
https://linustechtips.com/topic/454558-low-gpu-usage/#findComment-6098372
