Can anyone help me? I'll be building a pc for the first time and I got these components that I'm planning on buying. Do you think this will be enough to play AAA games (like gta V and fallout 4) at 60fps on 1080p? Anything I should change to improve this build?
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor
Motherboard: ASRock B85M Pro4 Micro ATX LGA1150 Motherboard
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory
Storage: Crucial BX100 250GB 2.5" Solid State Drive
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: Sapphire Radeon R9 380 4GB Nitro Video Card
Case: Fractal Design Core 2300 ATX Mid Tower Case
Power Supply: Antec VPF Series - 450W
Total: € 782,50
Someone told me I might want to get an AMD FX 6300 and throw in a Hyper evo 212 instead of an i5 to make it "future proof" , any comments?
EDIT: Please be specific when suggesting compontents as I'm quite a noob..
EDIT2: Knipsel.jpg Current build plans
https://linustechtips.com/topic/454487-first-time-building-a-pc/
i5 4460 >>>>>> FX 6300
The 6300 is a long dead CPU since it's no longer powerful enough for games.
Get a G2 or GS for the PSU - G1 and B1 are bad usually.
EDIT: Get 120GB SSD and use the cash on a H97 board if you ask me.
https://linustechtips.com/topic/454487-first-time-building-a-pc/#findComment-6097212
Good build I wouldn't change it although you might want to go for a XFX TS instead of that PSU and that person who said that was either trolling or really doesn't know what he's saying
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/454487-first-time-building-a-pc/#findComment-6097216
@ArneD follow your threads :P
https://linustechtips.com/topic/454487-first-time-building-a-pc/#findComment-6097251
Get a H97 board so you don't run the risk of having to update your BIOS. Also, get maybe a better power supply like a EVGA GS and G2 or an XFX TS or one of their modular models. And allocate less of the budget to the case.
 Which board did you have in mind? Also what's the point of getting another psu and what are the differences? Case suggestions are always welcome as wel.
https://linustechtips.com/topic/454487-first-time-building-a-pc/#findComment-6097263
Thanks for replying so fast, I didn't expect any replies this quickly... I'm a bit confused about the psu's tho
https://linustechtips.com/topic/454487-first-time-building-a-pc/#findComment-6097272
EVGA B1 and G1 are poor quality - usually have chinese capacitors, made by either FPS or Compucase, forgot which and overall are not recommended. G2 and GS are a lot better. Currently, the Antec High Current Gamer 620m should also be on sale for cheap.
You want a good PSU with a gaming machine to avoid issues and possible it dying.
https://linustechtips.com/topic/454487-first-time-building-a-pc/#findComment-6097295
Luckily for you we have zillions of guides! :P
Check the PSU whitelist in my sig for a few good ones.
https://linustechtips.com/topic/454487-first-time-building-a-pc/#findComment-6097300
My current psu is on your list tho :P
EVGA 500w?
Nope, not on there AFAIK and I definitely wouldn't put it in a system with an R9 380
https://linustechtips.com/topic/454487-first-time-building-a-pc/#findComment-6097351
Isn't that a lot of Watts? the 620m is 40 euros more expensive though...
About the H97 board, what should I pick.. my current one is 68.30 euros
https://linustechtips.com/topic/454487-first-time-building-a-pc/#findComment-6097355
A low teir though. I recommend this list and go for at least a tier 2 http://www.tomshardware.co.uk/forum/id-2547993/psu-tier-list.html
Asrock H97m. Cheapest will do. @don_svetlio explained that and the Cooler master Silencio 352 is quite good from what i've heard or the Fractal Design 1300 depending on your budget.
Steve
https://linustechtips.com/topic/454487-first-time-building-a-pc/#findComment-6097373
Cheapest H97 board you can find - doesn't matter
if the 520m is cheaper get that.
https://linustechtips.com/topic/454487-first-time-building-a-pc/#findComment-6097381
Better list than Tom's
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/
https://linustechtips.com/topic/454487-first-time-building-a-pc/#findComment-6097389
https://linustechtips.com/topic/454487-first-time-building-a-pc/#findComment-6097482
Those cases are more expensive so that wouldn't really help :P thanks anyways
https://linustechtips.com/topic/454487-first-time-building-a-pc/#findComment-6097487
Is it good now? If I can cut back on the case that would be even better, any good, cheap cases?
Looks solid to me
https://linustechtips.com/topic/454487-first-time-building-a-pc/#findComment-6097527
Thanks a lot man! Does this forum have a credit system so I can thank you or something?
Hah - the only thing like that would be the "like" system. But don't feel obliged, I just did what any other member would do :)
https://linustechtips.com/topic/454487-first-time-building-a-pc/#findComment-6097547
