what should my minimum specs be for a server used between alot of people, literally only used for data sharing so everyone can use the same files stored at one place. are these good specs.
Chasse
PowerEdge R430 Server (rack-mount)
Processor
Intel Xeon 2.6GHz, 20M Cache
Memory
16GB RDIMM (upgradable)
RAID Configuration
RAID 5 (hot Swappable)
Storage
3.6TB - Fast SAS drives (upgradable)
Network Cards
Broadcom 5720 Quad Port 1Gb
Embedded Systems Management
iDRAC8
Internal SD Module
Internal Dual SD Module
Internal Optical Drive
No
Power Supply
Dual/Redundant
Operating System
Windows Server 2012, R2 w/25 User Cals
Hardware Warranty/Support Services
3 Year/NBD On-site Service
Antivirus Software
Trend Micro
https://linustechtips.com/topic/453941-need-help-with-server-build/
I don't know much about servers but that seems very overkill, a low end CPU, 8GB's of RAM, and some storage will more than likely do. Also how many people is many people?
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
yes like excel files, pdfs, etc...
ok.
I would save a few hundred dollars and use FreeNAS or another Linux distro instead of Windows Server. You also wont need AntiVirus. If you are worried i know ClamAV works on Linux, but I have not tested it.
Unless you need to use Active Directory, I find it is much easier to avoid Windows Server.
I would also predict your maximum storage requirements now. You cannot add drives to an existing RAID array, so it is best to do all that now.
Aside from that, everything seems to be just fine.
~Judah
