Hi,
I recently watched a video where Linux added Led Strips to the Back ports Of his P.C .
I have looked for the video everywhere but I cannot find it :/ .
Does anyone have a link?
Many thanks :)
Welcome to the Forums!
And here you go:
http://www.amazon.com/360deal-Waterproof-Superbright-100cm-White/dp/B00PJWDM5Y/ref=sr_1_1?ie=UTF8&qid=1442859137&sr=8-1&
https://linustechtips.com/topic/453917-led-strips/#findComment-6088789
I would recommend getting some really good quality strips as it does make a big differance
'FrostNova' https://uk.pcpartpicker.com/user/Samsterstorm/saved/WtBWGX :
CPU: Intel 4790k | MB: Asrock Z97 Extreme6 | GPU: Gigabyte GTX 970 G1 Gaming (+200, +250) | CASE: NZXT H440 (Black & Blue) | COOLER: Full EK 240mm CPU Loop | RAM: 16GB Hyper-X Fury (4x4GB @2133mhz) | STORAGE: Seagate Barracuda 1TB & Hyperx 120gb SSD | PSU: Corsair RM650 | SCREEN: Benq G2750 | LIGHTING: Deepcool RGB LED Kit | KEYBOARD: CM Devastator | MOUSE: Logitech G502 | HEADSET: Hyperx Clouds White
https://linustechtips.com/topic/453917-led-strips/#findComment-6088810
Hi,
Many thanks :)
Welcome to the forums!
Youtube video: https://www.youtube.com/watch?v=xp-WenqUiQA
LED strip: http://www.aliexpress.com/item/5m-300-LED-SMD3528-60leds-m-Flexible-LED-Strip-Light-60led-m-IP65-Waterproof-White-Blue/1688086875.html?spm=2114.01020208.3.19.JxhsCN&ws_ab_test=201526_2,201527_3_71_72_73_74_75,201409_5
https://linustechtips.com/topic/453917-led-strips/#findComment-6088827
https://linustechtips.com/topic/453917-led-strips/#findComment-6088874
How is that? Just wire them to a molex cable or if you dare, a fan connector for voltage control.
Yes those will work perfect for the situation you described but not for USB power which is what was used. USB can only provide 5V with a max of 0.5-1Amp for most ports.
https://linustechtips.com/topic/453917-led-strips/#findComment-6090185
