I have a GTX 780 Lightning from MSI that I have tried overclocking, but can only squeeze another ~100MHz out of it. I installed the latest version of GPUz to check the ASIC quality, and it says 85%... doesn't this mean that I have quality silicone? I have always been weary to touh the voltage, so any tips on in depth overclocking is very much appreciated.
https://linustechtips.com/topic/453908-overclocking-msi-780-lightning/
Pretty sure Nvidia limit their cards to only add .87mv so no1 really ends up fucking their cards..., so you can't add too much anyway...
You prob do have to add some voltage to get more out of it, and if that does not work, then yeah... it is..what it is.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
Have you upped the power limit? @KingCry
Start with small voltage increments. But you can max out the power limit now. Asic quality doesn't mean much.
check out my gpu overclocking guide; link in my forum signature. if you have any questions, msg me
BigDay
Welcome to Kepler were Asic means absolutely nothing at all, best thing to do is hammer voltage through it and run it in the LN2 BIOS and see what you can do.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
