Hey!
I swopped my iphone screen and now it wont activte / open the sim card. I press the code and it's stuck at the loading screen. It also wont get any wifi signals. The clock on it are now showing 01:50 and it's 17:32.
What to do?
And also; this piece fell out:
Dirty I know. I must wash it ^-^
Current Build Logs : ~ "The Future is Back" ~ "NES, The Little Beast" ~
z170l || i5-6600k || Noctua something cooler || 2x16gb ddr4 || msi 1050ti superlowprofile || hdplex 260w psu
https://linustechtips.com/topic/453837-iphone-help/
@Noxz Could be some kind of battery connector? Like PC's have a CMOS battery, maybe it could be an iPhone equivalent. (Kind of looks like the top connector to keep the battery held in place)
And maybe could cause the "out of time" problem like a CMOS battery would do on a PC?
EDIT:
Looks like @MblaZe7run is right. Could ground it to the case.
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
https://linustechtips.com/topic/453837-iphone-help/#findComment-6087601
My guess is fhe sim card contacts arent where they shouldnbe. Try to remove and reinsert the sim card. Usually the time is kept by the internal battery that powers the device and it should eventually sync the clock.
https://linustechtips.com/topic/453837-iphone-help/#findComment-6087605
That would be a ground clip. It grounds the component it was attached to to the chassis. Not sure that's your issue, mine works fine after having one fall out. Which iPhone model? Mine is a 4S.
FX-8350 | GA-990FXA-UD3 | G.SKILL 2x8GB 1600MHz | 1TB WD RE4 | CM Hyper 212 EVO | MSI R9 290x Lightning | Corsair AX860i | Silverstone FT05B-W
Pentium G3258 | MSI Z97 PC Mate | G.SKILL 4x4GB 1066MHz | 500GB Samsung 2.5" | Stock cooler | Pending GPU | EVGA 500B | Antec DF-35
GoPro Hero 3 Silver | Netgear R7000 Nighthawk with DD-WRT | HP Officejet Pro 8610 | Canon iP110 | AudioTechnica ATR2500 USB
Downdraft cooler for mITX board (new build) | Desk mount mic stand | Pop filter | Anti-vibration mount for microphone | mITX case | 3rd monitor (matching existing 23.1" | Intel Core i7-4790K (for mITX build)
https://linustechtips.com/topic/453837-iphone-help/#findComment-6087606
I've got the iphone 4. I tried take every part out and re-build the phone two times. This included turning it on and of atleast 4 times and taking the sim out and in aswell.
A friend of mine said I've had to connect it to a computer so that the clock on the phone can sync with the real life, and thats why I couldnt connect to the network somehow. But I've got no idea on how to do dis ^-^
https://linustechtips.com/topic/453837-iphone-help/#findComment-6087639
Uhh... take the apple propriatary usb cable, plug it into the phone, and plug the other end into the pc?
https://linustechtips.com/topic/453837-iphone-help/#findComment-6087661
There's a "shortcut" somewhere. Two wires connecting that should not connect. THANKS OBAMA
https://linustechtips.com/topic/453837-iphone-help/#findComment-6089488
