Does it occur with every ISO?
https://linustechtips.com/topic/453369-epsxe-help/#findComment-6080610
whenever i try to run an ISO it says epsxe has stoped working ... i have version 1.7.0 and all the stupid graphics driver things and the ZLIB thing ... i cant figure out whats wrong
Compatibility. Change it to Windows XP/Vista
https://linustechtips.com/topic/453369-epsxe-help/#findComment-6080660
Change the Compatibility. Right click on the application and then go to Compatibility mode and then change it.
https://linustechtips.com/topic/453369-epsxe-help/#findComment-6080702
its not an OS compatibility issue, i've ran it on W8.1 before, and then it just magically stopped working...
https://linustechtips.com/topic/453369-epsxe-help/#findComment-6080723
Oh. It worked for me when I changed the settings.  :huh:  :huh:
https://linustechtips.com/topic/453369-epsxe-help/#findComment-6080730
getting epsxe working at this point is more so voodoo than it is a science...
i feel like at this point running it in a VM with a legacy system would work better...
https://linustechtips.com/topic/453369-epsxe-help/#findComment-6080741
Try the latest revision.
Edited by Godlygamer23
https://linustechtips.com/topic/453369-epsxe-help/#findComment-6080845
